TV question for anyone (including Malcolm)
Daeths
North Kent
T212 facelift, 2013. A few toys including pan roof, 19" rims, Harmon Kardon, nappa, privacy glass.
My better half bought a 'bargain' flatscreen LCD off ebay. It was £20 as the built in DVD player was broken (despite the fact we only wanted it for the built in DVD)....I know....don't ask. It was clearly advertised as broken...again, don't say it !
It is a Goodmans 15" GTVL 15n5DVD.
The DVD fault is that you load a DVD and it then ejects it after about 5 seconds, it does not spin.
Accepting she only paid £20 for it, but any ideas if this is a simple fix.
Xtractorfan
S class
I have quite a few broken items lying around, get your missus to call me they are going fairly cheap...
The pick up will have gone dead,,it needs to see the reflection when loaded,,it see's nothing and ejects it again.
The reflection gives a kick start to read the disc.
Many computer drives are the same
D
Daeths
North Kent
D
Daeths
North Kent
is this reapairable and a cheap part Malcolm or is it a throwaway ? The quality of the LCD is average to say the least, but would tide my boy over for his cartoon dvd's if we could get it going.
D
Daeths
North Kent
right just found the replacement part for £14. My question now is , is it a case of unscrew/connect and rescrew/connect or is there soldering /other stuff involved ?
Anyone know ?
Many thanks
They are plug and play,nothing to set up,,just remove the back and base and put it in, dead simple
D
Daeths
North Kent
many thx Malcolm, will order my part today.
Assistance greatly appreciated as always.
turbopete
Spennymoor
i dont get it. this is a question about a tv. what makes anyone think Malcolm would know anything about such things?:rolleyes::rolleyes::rolleyes::lol::lol::lol::lol:
I am forgetting fast the rotten things that are made these days:
turbopete
Spennymoor
well theyre not made to be repaired now i dont think. unless you can fix them yourself, they cost more to repair than to replace. or at least thats how it seems anyhow
Wirral_guy
Ness, nr Chester
2004 CLK270cdi Avantgarde
Part of the problem is that most electronic parts are made on high density circuit boards, using smd techniques and many are either acetate style (bendy!) or multi-layer boards which all make it difficult if not impossible to repair at component level on failure. The cost to supply even basic spares versus a new item is prohibitive due to the distribution costs. Add the hourly rate of a repairer and there are few items that we buy nowadays that are cost effectively repairable versus the purchase price of a replacement.
Dave
(an ex-computer maintenance engineer who got out when I stopped needing my soldering iron and multi-meter to repair kit:roll:)
D
Daeths
North Kent
right then. Have the back off the tv and looking at the DVD player which is attached by four screws.
If I buy the replacement pick...where is it ?? I know it is in the 'square' DVD player but it is not obvious. Any ideas please on how to guide me to the right piece ??
Many thanks
We always change the whole thing now, and most computer DVD are virtually the same
Frontstep
T210 320cdi
Heaven forfend that I am butting in but have you tried cleaning the offending part they don't work well with fluff and muck on them !
D
Daeths
North Kent
  • #17
sometimes the obvious are the best...will give it a go tonight.
Cheers
These things are vertically mounted and do not get very dirty and most these days have a lens sheild
C
C180 Chris
Cheers
If you're going to have a stab at cleaning the unit get some isopropynol (propan 2 OL) and a couple of cottonbuds.
It may well be that substitution is the best way forward as Malcolm has already suggested, but it will be worth giving it a clean just in case.
Rory
Cheshire, UK
It may well be a pickup (laser) fault but if it simply ejected on not seeing a reflection then surely it would do that if the drawer was closed with no DVD present?
I'd have thought more likely that the drive sees the disk but doesn't recognise it, hence it ejects it. If that's right then it could be the pickup, or other electronics within the drive, or possibly elsewhere in the TV.
I have had this fault on a PC and the supplier just sent me a whole new drive.
www.W140.co.uk&www.r129.co
