Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
To eliminate the possibility that my intermittant Amp problem, is in fact a bad speaker connection. I was going to replace it and any local wiring connectors in the tweeter pod.
I looked up the parts on EPC and found the tweeters ... for left and right door, and two
“Socket Housing Tweeter 2-Pin MQS # A0305452828” (couldnt make them out on EPC diagrams.
Per google these look like these.
I assume these can be opened up and changed?
Has Anyone changed / worked with these style connectors? Just checking they are not moulded on connectors?
It also says there are 2 other tiny parts ( one per door) called:-
“REP.SET Contact 0.75mm2 MQS”
I couldn't find these on Google, are they replacement metal bullets to crimp / solder onto the 2 wires?
I would really prefer not to have to solder onto the wiring harness.
Just doing my pre-removal research, as to what I need to buy before undoing trim parts.
WIS says use a long wedge to undo the Mirror Triangle Cover.
On ebay it looks like this ...
Am I correct to assume one just prises out the single clip (with the triangular wedged head) Near the top i.e. its not one you bend either way ... but just apply outward pressure as near to the pin part, as one can guess i.e. pull it outward and then lift up the tweeter pod to release the two flanges at the bottom ?
