prwales
Banned
- Dec 31, 2007
- Location
- South Wales
- ge300, w124 300e, various VW's
- Banned
- #21
and it will cost over £2,000 to have it fitted
Unless you do it yourself, then the only costs are machining for pistons/conrods, new gaskets and a rolling road setup session.and it will cost over £2,000 to have it fitted
Not if what d_w124 says is correct about the compression ratio.but you do need more skill than I have as well
I think on the 103 you can just bang them on,without lowering the ratio
its a farily low compression system as it stands and you can adjust the fuel octane setting but will not get the full potential of the system without lowering the compression ratio.
Is this kit still available by any chance???
yes it will fit the 3 litre engine in the w124's, the w107, the w126 and also the 2.6 litre engine fitted to the 190 series cars
I do but I'm not sure how to get it to you as I don't have a scanner, perhaps someone else has? If you are desparate, pm me with your address in NZ and I'll post a photocopy of it to you
