Two easy questions....
O
olliecampbell
Would this pipe not being connected cause any of this beautiful list of errors?:
P0410
P0307
P0311
P0309
P0312
P0308
P0310
P0300
And is this a secondary air pump (large black unit on the left)?:
Not had time to look up that list but the secondary air pump only plays a small part in the running of the engine,,what is it doing
O
olliecampbell
The errors are all related to Secondary air system and misfires...
Tried resetting via the OBDII and they eventually pop back up. Re-connected the pipe in the first picture and was wondering if that might have caused the misfires/secondary air system problems.
I would normally test myself but the battery is on charge at the moment as it's totally flat!
Just for reading I have sent you a aux air pump paper for the SL
O
olliecampbell
OK thanks, I'll have a good read.
