kevinororke
After much research and lots of comments on this forum I decided to buy a set of 4 Barum Bravuris 196/65 R15 91H for my C220 CDI Estate. The deciding factor was all the data proving that tyres with less than 3mm tread are significantly compromised. If I'm going to replace tyres at 3 - 4mm then they have to be reasonably priced. National Tyres in Edinburgh did 4 tyres, valves, balance, fitting, tracking and old tyre disposal for £198 all in. In addition the Barum Bravuris seems to come near the top in all the published trials. Down side is that they are directional. To early to say much about them. They are definitely quieter than the previous P60000 even with more than twice as much tread depth. Bottom line seems to be that an economy tyre with 4mm of tread is always going to beat a top of the range item with 2mm
Regards, Kevin
Regards, Kevin
