- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Sorry to see the bickering going on. No matter what one thinks that they know, there is often a better solution to what you have been doing all your life. There is nothing wrong with learning more and getting new idea's, if I had not read all the technical books that I could get hold of I would have been out of business years ago. Another example is to watch someone else doing a job that you have done, and often one can pick up invaluable tips, or ideas that you had never thought of no matter how experienced you may be. The situation is worst when you are working on your own, and the mind is set on a one way track to do the job. this is often shown up in the building trade, where a guy does it the same way as his father did it, and that it often very wrong as most small builders do not keep up to date, there is a huge difference in fixing something, or curing a fault for good with modern fast changing technology.
Back to the tyre pressures. Yes the label in the fuel lid gives both unladen and fully laden figures.
These figures are not gospel but a good guide as to where to start from, these days we have rims that are larger, and the sidewalls smaller, it is often hard to just run at the recommended pressures, as on pot hole can wreck the wheel and tyre. Slightly over inflated will stop this from happening, under inflation will cause excessive heat to the side walls, over inflating will not, but can give cause to difficult handling in the wet. I think that by juggling a little on the over inflated is the better way to go.
Tyre pressures are dictated by the weight of the car. I run my SL500 with a pressure in between the two as an all round compromise, the ride is not too hard, my wheels are safe against possible damage, if there is signs of more wear say in the center of the tyre, then I may lower the pressure a touch towards the end of the tyre life.
To test a wheel for possible pot hole damage, one has only to roll the car head on to a kerb and check how far the tyre has deformed
