alanmercer7
Does anyone know if a 2003(53) sl55, should have some sort of low tyre pressure warning system, and if so, how do you set it up.
An alert is triggered if there is sudden pressure loss. Else, the pressure is transmitted every minute.
DIRECT systems use transducers mounted inside the wheel rim.
INDIRECT systems compare wheel speeds from wheels on the same axle.
As of now, EVERY new vehicle supplied in USA must have a DIRECT system fitted..
BERU gen1 sensor life is about 7 years so all the MB vehicles that debuted with this system are about to need new sensors at £100 a go
That's interesting - I hadn't heard about that proposal.
I think the USA situation had a lot to do with the Firestone/Explorer thing..
