Tyre size for AMG 19" rims please
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Mickey42, May 9, 2019.
  1. Mickey42
    Mickey42 Active Member
    34
    3
    Apr 26, 2011
    IPSWICH, ENGLAND
    Your Mercedes:
    2005 CLK 320
    Hi Guys. My 2005 CLK 320 is beautiful but the ride on a dodgy road is an uncomfortable ride ( I am 50!) I have 19" AMG rims on it but I think I need to change the rear tyres at least as it is the rear which feels`too hard`. Currently on 235/35`s, any ideas on what I could change them too, wider/higher? Thanks.
  2. vtaylor78
    vtaylor78 Senior Member
    1,315
    505
    Jan 5, 2012
    Northamptonshire.
    Your Mercedes:
    E350 CDI Coupe W207 2010 \ SLK 250 R172 2011.
    You won’t get a higher profile unless you go 18s , I think.
  3. malcolm210
    malcolm210 Senior Member
    3,348
    472
    Aug 21, 2005
    ^+1 yes our roads aren’t fit for 19in wheels unfortunately, air suspension helps, the W213 handles 20in wheels very well so MB have made progress but not much consolation for everyone else. I would go for a set of 18in wheels
  4. LostKiwi
    LostKiwi Senior Member
    18,425
    8,572
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    My r129 came on 19s shod with 235/35 and was quite bad on poor surfaces. The rim also sat outside the tread so was vulnerable to kerb an pot hole damage.
    On that I went to 255/35 and they fit well though are very tight at the front on full lock.
    The wider tyre has given 7mm more sidewall so has helped with ride as well.
    Whatever you do to the rear you will also need to do to the front. If you don't your cruise will fail to work properly, ABS and ESP will also have problems as they all rely on information from the wheel speed sensors to operate and if one set show a lower than expected speed compared to the other set will start to behave oddly.
    Here's the 129 on 255s:
  5. JBell
    JBell Senior Member
    10,136
    2,316
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    CLK should have 225/35 R19 front and 255/30 R19 rear tyres
Share This Page
