Looks like the time has come to soon replace both front tyres on my A140, after about 14K miles. (Conti Ecocontact)
As far as I know the legal limit is 1.6mm over 75% of the tyre. But I suspect that replacing the tyre when it gets to 3mm over 75% would be more sensible (as recommended by Continental)
As far as I know, new tyres should always be fitted to the rear (putting the existing rear tyres to the front, and fitting the new tyres to the rear) Should the rear tyres be moved to the front, keeping the same side
(i.e Left rear, to Left front) or should they be crossed over? (i.e Left rear, to Right Front)? The Mercedes Service schedule (assyst) does not perform rotation as part of the schedule on the A class.
Tyre wear is as follows:
FL 2 4 3 3 FR 4 3 4 2 (average 3.125mm)
RL 6 7 7 7 RR 7 7 7 6 (average 6.75mm)
Above tread depths as as on the car (i.e front left depths are 2mm on the outside, 3mm inside - Front Right 2mm on outside, 4mm inside)
Does the wear pattern look reasonable? Is it normal for the outside of the tyre to have slighly higher wear than the inside.
Assuming that the tyre started with 8mm, is it usual to show the ratio of wear re front vs rear tyres (approx 2800miles per mm on the front, and 11200miles mm on the rear - i.e fronts wear 4 times quicker than rears)
Found some info on the ATS Euromaster site,
ATS recommends:
Balancing: Each time a wheel is fitted, or when wheel are swapped to a different location.
Geometry: After a violent shock, after abnormal tyre wear, diminished road holding, at least once a year.
Looks like I therefore need, two new tyres (fitted to back), all wheel rebalanced, and geometry checked/adjusted!
Does this seem reasonable?
ATS recommends:
