:grin:
Hi All
After three days at the main dealer, the problem with the 1400rpm idle appears cured. Software was OK, fitted new throttle made no difference. Tried new battery, bingo. all done under warranty. S-A-M/U-N-I-T pretty much hit the nail on the head! Thanks. ECU compensates for low voltage with faster idle, typically 900ish rpm, but if the battery has a fault it over compensates and gives the symptoms described in my earlier thread. Also occurs on R-Class and GL's.
Thanks again for the help, much appreciated.
Regards
Hi All
Regards
