Uprated SL500 springs?
roscoc180
Cornwall
R230 SL350 black/blue-2004
Hi allm
I am looking at buying some uprated lowering springs for the SL because I find it tends to wallow, has anyone any ideas on where I can puchase these.
I see there are a few AMG engines on Ebay,just a thought ;):D
roscoc180
roscoc180
Cornwall
will take a look.
Thanks Malcom:D
roscoc180
roscoc180
Cornwall
Hi all,
Have purchased a new set of springs, I take it it is just a case of undoing the top of the shock and the wishbone should drop enough to remove the spring.
Your ideas would be appreciated.
Ross
roadhog
Sunny Norfolk
W124 300D x2, C124 300
Hi all,
Ross
:shock:
I know nothing about SL's but I'd be surprised if it was that easy.
roscoc180
roscoc180
Cornwall
Thankyou Malcom,
I take it you mean car on stands then a jack underneath the wishbone and undo the inner bolts then drop jack. Reverse to refit.
Ross
Thankyou Malcom,
Ross
Yes. lower the whole wish bone, using a trolley jack or other.
Many do it that way when they do not have a MB spring compressor
roscoc180
roscoc180
Cornwall
Do I leave the outer end/ball joint connected or leave on and lower the inner.
Ross
Ross
That must come off or the wishbone will not come down level.
As it is the same as a 124 if you do a search there should be some info on this for 124 or maybe someone else will join in
roadhog
Sunny Norfolk
Does that work on these? When I did mine, the weight of the car wasn't enough to be able to compress the spring enough to get it back together.
Good point,,I am posting on what I have read on here, the 500 is a heavy lump,,a spring compressor makes it dead easy
roscoc180
roscoc180
Cornwall
Thanks Malcom,
As usual a great help.:)
roscoc180
roscoc180
Cornwall
Hi all,
Just an update, fitted new springs today and the result is a huge improvement. Apex springs (30mm lower) and Bilstein shocks all round, fitting went well. The fronts I managed with two compressors, although tight for space it is do-able (the internal one is the easiest to use I should imagine) The rear was a bit of a pain as you have to remove the boot carpets and aluminium bulkhead to get to the shock nuts. Then I found the easiest way was to place a jack under the inner bush of the wishbone and drop it to remove the spring. The only thing I did wander is what is the module with the little arm that fixes to this inner bush bolt, the arm sits under the wishbone?? The car sems a lot more positive with no wallowing.:p:p:p
roscoc180
roscoc180
Cornwall
Yes that's the one, now I know.
Thanks malcom
