Funny buddy , but halfway through an oil change is probably when the oil is no longer in the carHi sorry for the late reply. It was urgent because I was half way through doing it and couldn’t find it. Gave up. Ordered an oil extractor lol
Yes, and when you find out they’ve sold you the wrong filter...Funny buddy , but halfway through an oil change is probably when the oil is no longer in the car
Your CLC 220cdi has a metal sump, not a plastic one.
The drain plug is often uber-tight, so you're going the right route using an extractor pump.
Just make sure the oil is good and hot when you extract it.
Or get your other half to do itYeah I did see something that looked like that. Tried to turn it but came to the conclusion I need to work harder in the gym
Nearest I got to that was wondering what the liquid sound was hitting the floor .... You guessed it, no sump plug in yetYes, and when you find out they’ve sold you the wrong filter...
That can get expensive quite fast, it’s a method of getting more of the old oil out though...Nearest I got to that was wondering what the liquid sound was hitting the floor .... You guessed it, no sump plug in yet
You only do it once buddyThat can get expensive quite fast, it’s a method of getting more of the old oil out though...
