urgent CD changer help required!
Yosser
Edinburgh
1998 w202 estate, audio 10 cassette head unit, MB 6 disc changer in boot (OE retrofit)
I've got a bit of a problem with my CD changer.
Everything used to be ok, I then installed a different head unit which wasn't connected to the changer. This worked ok too.
I have now re-installed the original audio10 unit as I have sold the car (hence the panic).
When the CD button is pressed, the display says No CD. There is power at the changer, as the eject function works. I just can't get the changer to function.
The battery was disconnected for a wee while, but I've had it disconnected in the past with no ill effect.
Any ideas please??
I'm in a bit of a flap as the car is meant to be getting handed over in the next day or two.
Is the cable from the changer to the head connected correctly. Not sure if yours is but a lot are optical leads, so it may be dirty/damaged. I would take the connectors off then re-seat them in the first instance.
Y
Yosser
Edinburgh
Problem Solved!
Thanks for the response Blobcat.
After a bit of searching on the forums, and the wider net, I have managed to get it to work.
There is no C connector in the car. The changer was a retrofit (by MB) and the only extra connectors were the optical one and the one I missed ;
one wire connected to pin4 of the C connector on the head unit.
All works ok now.
Was able to confirm pins on this site;
http://www.hanshehl.de/multimedia6.htm
Thanks again.
Optics did not start until late 99 on most models, if it is optical there is a bright orange single connector that must be plugged in at both ends, other than that I can can only think of re powering up with everything connected.
Malcolm
Sorry I started this 1 hour ago, but the phone rang
