Hi all I have Vito 1999 witch starts only if is pushed for few meters and if I try by the key will keep weeling until batery runs and still not starts. After starting pushed runs perferctly and is all OK Only problem is to be started. If somebody know any think please let me know. Thank you.
battery hi have your battery checked it may not be producing enough amps even though it turns engine. also check leads are tight on starter as this is another possible starting problem good luck chris
