V230 battery change
leejohnfrewin
Can anyone help me on how to change the battery on my v class, I know it is under the front seat but can not work out how to get it out and a new one in ??
Many thanks
Lee
Cole@MBS
www.mbssouthampton.co.uk
Theres a clamp running down the side with two 13mm bolts, on some you also have to remove a couple of the seat bolts, tricky but not hard.
Welcome to the forums!
L
leejohnfrewin
Seat removal.
Thanks for the reply, just changed it over.
To get the seat off I removed the 7 securing bolts that attached it to the movable carriage (13mm). This then gives you free access to the battery terminals and as you say brackets that hold the battery securely. Once all these are detached then the trick is getting the battery out. I did manage to eventually pull it straight up and out but when putting the new battery back in I found it easier to slide it in from the side, by removing the cover at the side of the seat base. Then obviously reconnect everything and pop the seat back on, beware the seat is easier to take off than pop back on, but eventually I got there.
Many thanks
Lee
www.ckinsurance.co.uk
