vacuum pipes
markwill
I have a merc 190e 1993 2.0 auto.....
Can anyone please explain or send a photo or diagram to me, with regards to the set-up of the vacuum pipes. Where do the ones from...either side of the gearbox....from under the injection manifold....from the two branch rubber fitting on the n/s of the engine,injection manifold and to the inside of the n/s wing, all go to...you know what i`m on about....your help will be much appreciated
mark will
turnipsock
Port of Menteith
I too would like to know the layout of these pipes for my 230TE.
There is a switch near the battery, there is a pipe from there to the gearbox...which side of the gearbox should this be attached to? (It's a black pipe with a biy of red)
pascal
near Dublin
sl320/1999/3.2
The vacuum pump is under the back seat on 124 (think its the same for 190) 123 is a completely different system run from engine.
I beleive the CDs on Ebay have complete diagrams (unlike Hayes Manuals)
But this link will give you a good start with some pictures:
http://ow.no/index.php?option=content&task=view&id=98&Itemid=86
So when you turn the key (or press the remote) it sends a signal (electrical) to the pump which in turn opens the doors, boot, and petrol door by way of vacuum hoses (yellow).
I suppose thats a start.
The only other items of the 190e that i'm aware of (not sure) using vacuum is the headlight adjusting.
The w124 also uses vacuum to control heat distribution (opens and closes vents) for windscreen and feet, as described by Keith in tonights post: http://forums.mercedesclub.org.uk/showthread.php?t=9794
Photo also
Pascal
turnipsock
Port of Menteith
It the vacuum pipes to the gearbox that we are worried about.
The central locking is powered by a pump under the rear seat and is all on yellow pipes.
pascal
near Dublin
sl320/1999/3.2
Sorry for being so little help, Turnipsock.
I said I'd try to 'give a start'.
The intake manifold vacuum is being discussed in a thread running alongside this.
http://forums.mercedesclub.org.uk/showthread.php?t=9687
Economy gauge , difference of w123 cl system etc.
Not sure of the two pipes you mention (just going from memory)(aged memory),
there are 2 pipes going to the headlamps (for adjustment).
Hope this may be of benefit to some people
Pascal
Tel: 020 8863 9233
