Vaneo: Starter turns but engine doesn't catch
guy.harwood
Hi, my vaneo intermittently refuses to start although the engine turns over fine. It has on occasions started, then within 10 secs stalled, and then refuses to start to again. It usually starts regardless after a few minutes trying.
Any ideas ?
Cole@MBS
www.mbssouthampton.co.uk
Injector passing !!!!!!!! new one needed!!!
G
guy.harwood
New injectors - sounds expensive. Oddly enough, the problem is intermittant, and once the engine is going (for more than 2 minutes) works OK.
G
guy.harwood
it's an 04 plate with about 75k miles
G
guy.harwood
We have tried using the spare key in case it is an immobiliser/key problem, and apparently it was OK yesterday ... weird.
mattkh
England
A160 W168 1999 1.6
Thanks for the feedback.
I wonder if it is time to change the key fob battery.
G
guy.harwood
Ended up taking it to Merc, after a number of days testing/replacing bits - it turned out to be the fuel filter!
