Very bad fuel consumption
ahmadsharbaji
C230/2007/272
Hello! I'm almost tired of figuring out what is happening inside my car.
I have a W203 V6 C230 Sport 2007.
I have no fault codes on the engine or the transmission. But, Here are some apparent symptoms that I'm facing:
  • I am facing a hurting/ugly smell out of the exhaust (not all the time but especially in the first start).
  • Facing hard starting up when I start the car at the beginning of the day (temp here is around 20°C).
  • Very poor fuel consumption! This engine should consume about 160 km in the city per tank. It really does go 100 km max!
  • Sometimes, some hesitation.
After hard and deep research, I'm almost sure that my problem is the Mass Air Flow Sensor (MAF). I ordered a cleaning spray, but haven't received it yet. But with this post and the attached pictures of the live data (Please see the links), what do you think is the solution to the problem? I have read that the result of the O2 sensors should be between 0 and 1. But I have about 1.45 !!!
I also have thought, as long as the O2 sensors are giving results, does this mean that they are working properly?
Data stream results:
https://i.ibb.co/ZV4MGf0/1.jpg
https://i.ibb.co/WzNmnPn/2.jpg
https://i.ibb.co/hC90wD9/3.jpg
Have you sorted the issues from your other thread?
What's the running temp like? is it getting to temp within ~8 minutes?
mioba
Nottingham and Köln
A MaF will throw a fault code. Have you tested your injectors. Could well be an injector leaking.
A
ahmadsharbaji
C230/2007/272
Those issues are gone because I replaced the ignition coil by a new one. So, basically the misfiring are done but now I want to fix the fuel issue :(
I recommend you update the previous thread
