Very HIGH RPM= HIGH MPG
roach_juts
hello
i am wondering that my 1990 wagon has a high RPM, when the car is at idle the RPM is around 500 to 600 rpm which looks normal , but when i am driving it around 60mph the RPM is at 3K RPM , when i speed up to 80 MPH the RPm will me 4k RPM .. this seems not to be normal , because my other w124 if i run it at 80MHp the rpm is 3K RPM....
i did a change oil already, with ( oil additives)
added fuel injector clean & even sprayed the carb & injector
but nothing changed
i am thinking changing the distributor, rotor, fuel filter & O2 sensor
i hope this will help the RPM go down to normal
ANY SUGGESTION & ADVICE ??
thank
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
400 rpm at 80 mph is right for most of the smaller-engined W124 estates. Doing the things you propose won't help
The only possible problem is that the car is not going into 4th. If that was the case, though, it'd be pulling even more revs than it is now
It's just a characteristic of the car
Nick Froome
www.w124.co.uk
brandwooddixon
Wolverhampton
S63 Coupe 2014
You don't state what car you have, engine size or even if it's an automatic.
High rpm whilst driving wont be anything to do with the engine, it will only relate to gearing and the gearbox.
As Nick says, if it's a small engined estate then it will have lower gearing and thus rev higher than a larger engined car. This is all down to the gear ratios.
If car is an automatic and it has a similar sized engine to your previous car then it is possible that it is not switching to the highest gear or there is some torque convertor slip.
I believe that some of the user manuals state what rpm to expect for given speeds and gears.
I do have a table for the given RPM at all speeds but the engine size is not mentioned here
R
roach_juts
ohh i for got the engine is a M103 & the car is a 300te 1990 model
Seeker_UK
I would say for a 4-speed that sounds about right.
300TEs are not known for their fuel economy. ;)
Tel: 020 8863 9233
