Very Squeaky front Suspensio
L4FOU
Hi All
Can anyone help with this problem??? Recently changed the drop link on the driverside front on my C180. Went on fine with no problems but since then there has been a very bad squeaky noise coming from the same suspension - sounds like really old bed springs loud too. Funny thing is - it starts about 15-20mins after driving and disappears within 5mins of stopping so can't see/hear where its coming from. Took it back to the garage where the work was done and they couldn't fine anything...Any ideas please?
I do not understand the stopping 5 mins before,,,does the lenght of the driving time make a difference
wullyuk
Hi All
Do you have xenons? I've just discovered squeaks coming from the level sensor / switch ue to it being corroded!
LYNALL
Kent
Spray one bush at a time with wd40 and you will soon work whats at fault.
Lynall
Dave Brooker
Hi All
Anti roll bar bushes?
Silicon and PTFE work quite well on the roll bar bushes
kth286
E320 Coupe 95
The bush is twisted to excess.
The car should be in it's normal driving position (resting on it's wheels) when tightening suspension bushes.
The bush is then in it's proper working position and the rubber will not tear, and the bush will last for a very long time.
BUT you will have seen how many garages use car lifts that lift the car but leave the wheels and suspension hanging AND they tighten the bishes when in that position - totally wrong !!!!!!!!!!
If they have not got the poroper lift then they should at least raise the suspension with a tall jacking device before tightening the bush.
MB TECH WARRINGTON
agree regarding wishbone bushes, but the op only replaced a droplink so not very likely in his case
