Viano 2007 (W639) sliding door fault
djl
city
Viano/2007/Diesel
Viano (w639) 2007;-Sliding Door will not 'catch' when I shut it Can anybody help.and the model has fancy panels which are difficult to remove without removing the whole door,which looks very heavy?
M80
Derbyshire
Panels can be removed.
If you start adjusting the door hinges and D hasp you'll be there forever, but I'm not saying that isn't the answer.
The lock is at the rear for the door, you might try giving it a push as it gets to closed.
In there there is a micro switch that can fail. I never found a replacement. I believe new locks are approx £150.
It sounds like your door hasn't reached the contact plates at the fore??
Only clean these plates with gentle abrasive, kitch en surface cleaner for example. The protective coating can be removed if not.
These can be exchanged n/s to o/s and turned upside down. Be sure to tie a retainer on the cables to stop them falling down the pillar.
D
djl
city
Viano/2007/Diesel
Hi M80,
Sorry for my slow reply but Illness has interupted my work on the Viano. I have removed the lock at the rear of the door and it seems like new. every thing seems to be working as it should.The microswitch I don't know how to test so I will try the plate on the opposite side (that is working perfectly. I have a Diagnostic tester but when I set it to diagnose it puts a message up that says Fault on circuits 30 and/or 31 so it lacks a 12v feed and Ihave checked all the fuses and relays.. Will get back to you with the result for changing the plates over. Thanks for repling.
M80
Derbyshire
Testing the lock is confusing.
There are open, closed and deadlock positions.
I recorded the meter readings in the different states but it's XL and won't attach here.
I've pm'd you with my email, I can send that way.
M80
Derbyshire
D
djl
city
Viano/2007/Diesel
I don't seem to be able to print it. Have you any suggestions as to how to print it?
D
djl
city
Viano/2007/Diesel
I've managed to print it via Dropbox. I'll speak to a guy who may be able to make sense of it. Thanks for the help.
D
djl
city
Viano/2007/Diesel
I've fixed the problem, but at great cost. Replaced the door-lock, cost £232.80!
  • Like
Reactions: M80
M80
Derbyshire
The old lock could be useful for diagnostics.
This is a common issue and being able to diagnose and possibly source what may only be a micro switch could save others.
D
djl
city
Viano/2007/Diesel
Too much on at the moment but as soon as I gst the chance I'll take it appart.
