[Video included] CLA 200 W117 Rattle/Grinding issue when engine is up to temp
Skalas
CLA 200/ 2013/ M270 1.6l
Hello everyone,
I drive a 2013 Mercedes CLA 1.6L Petrol (W117/C117). M270 Engine
About six months ago, my alternator failed and was refurbished by a mechanic. Since then, it’s been working fine without any issues. While the car was in for repairs, I also had them inspect the timing chain due to a noticeable rattle during cold starts. They ended up replacing the timing chain.
Recently, however, I’ve started noticing a strange noise under specific conditions. What’s odd is that the car actually performs better when cold compared to when it’s at operating temperature.
The noise itself is quite distinct — a rattling or grinding sound — and appears when the engine reaches approximately 60°C and up. It lasts for about 5–10 minutes and then disappears completely. Here’s a breakdown of the situation:
  • The noise is present whether the car is in neutral or drive, which rules out the gearbox and driveshaft.
  • Heat shields have been checked and are securely fastened.
  • Engine mounts are in good condition.
  • Oil levels are within spec.
  • Oil type: This might be a potential issue. The mechanic made a few mistakes during the job, so the wrong oil may have been used. I’m planning to do an oil change soon and will switch to the correct spec (MB 229.5).
  • Additives used: I added Liqui Moly Hydraulic Lifter Additive (can’t say if it helped) and Liqui Moly Injection Cleaner just in case.
Given all this, I suspect the issue could be related to oil pressure or viscosity — especially since the problem begins at a certain engine temperature and then goes away.
I’ve attached a video of the noise for reference. If anyone has experienced something similar and managed to resolve it, I’d really appreciate your input.
Thanks in advance!
SL63 Mark
Wilts
R231 SL63 AMG
Sounds a bit drive belt/ancillary to me
Skalas
Thank you for the reply, i have changed the drive belt 2 weeks ago as well. But the sound was there with the old belt as well. Do you suspect maybe a pulley?
Always worth changing the idler and tensioner at the same time - also turning each item by hand to feel for any tight spots and/or grinding / bearing failures
Skalas
Thank you. Will check it out over the weekend.
Your going to need to scope around the engine, whilst somebody revvs it to get the noise to appear.
I suspect the cam actuator is faulty and not locking
Skalas
I did just that last night and the noise certainly seems to originate from the cam actuator/Adjuster side. Thank you. This actually makes sense.
Good job.
I would not run it until fixed, as that bad actuator will damage a chain quickly.
