i will do my best to get this in writing, the gcl warranty covers for any failure due to the remapping work mercedes warranty (in my view) will not be invalid as thay can not just "blame" the remap for anything. It dose however state in GCL terms that they will cover any issue's that the remap can cause.
I still wonder why the map should be "invisible"?
The MB dealer knows it's been done, your insurer knows it's been done (I assume). So why all this explanation as to how it can't be detected? I could understand why it should be protected so it isn't accidently over-written but you say it can be over-written?
I assume the glc would reinstall the map should this happen?
But you will never be able to prove it was due to the remap. And Mercedes can set T's and C's for their 3 year warranty as lots of other manufacturers do too. Saying the warranty is void if you use a non-approved chip is common practice by most major car makers. They guarantee the car if you drive it as supplied by them. Not if you modify it in ways they have not specifically approved.
That would be difficult seeing as they're not allowed on here anymore. I missed what happened though as usual.Perhaps GCL, if they read this, could enlightem me.
Some of you need to get laid !!!
I have also noticed the revs are much lower at 30 MPH and at 80 MPH this works out at around 200-300 Revs different.
I went out for a test run with Tony and we tweeked the gear box for prime shifting .
