anthony evs
- Jul 4, 2007
- Thread Starter
- Thread starter
- #61
Hi Alex,
Just read over the thread, noticing post 46 by mbsc (rob) he states timing at 15 degrees after tdc, but post earlier mentioned timing to be 20 degrees before tdc.
I have set the pump to 15 deg after tdc, hope rob can confirm this later.
Also, some additional info on the tensioner.
When i tried to remove the tensioner complete, i could not budge it out of the head, so removed the end cap and releived gthe tension that way, by removing the cap and spring. As its on the bulkhead side couldnt see anything else inside the tensioner. When the head was removed, could then get a good purchase on the tensioner body and remove it from the head.
When the timing cover was removed, i noticed a small spring (about 5mm dia and 25mm long, along with a spring holding washer on the chassis, on seeing this, my heart sunk and knew it had come from the tensioner, and thats why the tensioner wasnt working, because this small spring and washer were not fitted back when i reassembled the tensioner on the workbench.
The small spring and accompanying washer must have fallen out when i was pullng the head off the block. Gutted.
I managed to find a schematic of the tensioner on the web, and this is definately the case, so at least i know why it wasnt working properly.
I have now got a new tensioner ready to go with the new chain.
Thanks for all you help guys, please just need to confirm before i fit the head tomorrow that the pump timing is 15 degrees after top dead centre no.1.
Thanks very much, and best regards,
Anthony.
Anthony.
