thetaline
New Registration
I have a Mercedes Vito 115 Dualiner semi automatic 2006. All of a sudden the vehicle doesn't want to come out of park (except by the override button under the gear stick console) and then only into gear (drive, reverse etc) but with a bit of a bump.
All electronics connected to the gearbox seem to have failed: No gears displaying on the dashboard any more - not even park, no reverse light when in reverse, no lights on the gear stick console. With override button pressed the van will go into D and reverse etc, but will not shift through the gears automatically - it just stays in first gear, as if the computer is just not working or something. There are no knocks or grinding - all sounds absolutely fine.
What is the fault? I'd really appreciate some advice from an expert and an idea of cost.
Thanks.
Thanks.
