Vito 639 steering joint
A
Andrew Roberts
Vito 2004 2.2
  • #21
Ok thanks ,I will let you know,but if it does not sort itself out,
Does it have to be a special computer?
mattkh
England
A160 W168 1999 1.6
I am not sure. Is the ABS light coming ON as well or not ?
A
Andrew Roberts
Vito 2004 2.2
  • #23
Oh no,abs off,
I drove it around 18 miles today,only driven around 40 miles since failure last October,tc light on then eml ,maybe in limp,but restarted,booted it a bit eml off now after clearing out a bit
A
Andrew Roberts
Vito 2004 2.2
  • #24
Hi again,like I mentioned beforevito 639 after lower steering shaft,I believe I messed the steering up
Now traction control light is on after switch of and restarts and moved a little comes onbut now eml comes on
Steering straight,wheels straight
With a very little play
Should I try moving lower steering column 1 spline either way .
mattkh
England
A160 W168 1999 1.6
Did you replace the ABS pump a few days ago..?
mattkh
England
A160 W168 1999 1.6
Was there a module attached to it.
If there was, was there a earth wire close to the module. Clean and improve this connection to correct the traction control warning.
A
Andrew Roberts
Vito 2004 2.2
  • #28
Thanks for the reply,
At the moment I do not have the abs light on
The traction control light and limp mode
This started immediately after I played about with steering replacing lower steering shaft
A
Andrew Roberts
Vito 2004 2.2
  • #30
Yes we'll in the street,this is an ongoing project,it's on the road,but have vibration, while driving,it will have a service this week,because it's been standing for a long while
A
Andrew Roberts
Vito 2004 2.2
  • #31
I will also have a good look at the older part of the propshaft
