Valentinos
- Apr 26, 2019
- Mercedes Vito w639
Hey guys. i have a problem with my Vito.The turbo keeps cutting out when the van goes back to tick over. If you keep the revs up its fine but when it drops to below 900 rpm the turbo cuts out when you accelerate - its just flat. If you turn off ignition and then start the engine again it's ok till the next time it drops to tick over. Would a faulty low turbo pressure sensor cause this problem? The problem seems to be getting more frequent as it only occurred sometimes, but now it's getting worse . Are there any possible solutions?
