Alans dad
- Feb 12, 2019
- Vito 109cdi 2005 2.1 long
I have just got a 2005 2.1 Vito109cdi LWB van. The rear window washer jet is not working. I have checked the pump by disconnecting the ribbed hose at the reservoir and that is fine and squirts water out with a good pressure. The ribbed pipe/hose then disappears up behind the bulk head and does not reappear until the rear door hinge where it is bundled together with the wiring loom. I have disconnected the short rubbery hose from the rear wiper and no water comes out so the problem is not a blocked wiper jet. Ergo the problem lies between the wiper jet and the pump. Are there any valves or accessible joints in the hose? Are there any points where the hose might get pinched or kinked? Is this a common fault and how easy is it to fix or put a new hose in?
Thanks for any help on this.
