Vixser
Hi guys, I recently decided to sell my van, and I think it might have heard me because it's since started developing a couple of small problems that I really would like to have fixed before she goes!
I have an S reg diesel Mercedes Vito van. It starts perfectly fine from cold, glow plugs warm up fine and the light goes out, and it starts first time. however when it's been running a while and I stop for a short while, for example to get diesel, it wont start properly.
When attempting to start at the fuel station, the glow plug light wont go out, even after 5 mins. If I attempt to start it anyway the starter motor turns just fine and it sounds like it's going to start, however it just wont catch. If I put the accelerator flat to the floor and attempt to start it, it turns over and runs, but it rumbles at just above stall point and letting my foot off the accelerator makes it cut out.
I eventually got it started by getting my sister to start it with the accelerator flat to the floor so it rumbled, and manually opening the throttle from under the bonnet. After revving it a few seconds, I let it go and the van ran as normal.
My local mechanic said 'I'll need to see it do it before I can try to fix it' which we tried, and typically it worked fine, however it's done this a couple of times and I really don't want to pass this problem to the new owner. Any ideas what part I'll need to replace to stop this happening? Big thanks in advance for even reading through this.
