I have a 2017 Vito with steel wheels, and rubber valves. One of the wheel rims is dented - doesn't leak any air, but will be best swapped for the spare which is full size and looks to have a new tyre on.
I'm not sure how the Vito TPMS system works, as the valves look rubber I'm thinking it may be with the ABS and the wheel rotation, rather than each wheel having a sensor - so basically can anyone advise if 1) do the wheels have sensors fitted ? and 2) will the spare have a sensor in it and if so will it need to be coded .....
