clive williams
- Aug 23, 2005
Hi All,
Thought you might like some feedback on some Vredestein Ultracs 225x55x16 96W (on 8Jx16 rims) fitted to the barge - E320CDIT(or S)210 - I fitted them just about a month ago and I've been trying them out since. My comments are:
Handling - V good, sharp with good feedback
Roadholding - V good, have'nt found the limit yet!
Wet braking and grip - excellent. The only time they've noticed it was raining was on a polished manhole cover, but these are not supposed to be a rain tyre.
Wear rate - unknown but I'll tell you in 2 years time. These tyres are so good that I probably won't worry.
Noise - sorry, I normally don't notice unless it's a set of mud terrains. The roads around here are so noisy anyway you have to keep the radio on full volume.
Price - £470.00 all in for 4, which is good for the size and speed rating. I found Jeff Fowkes in Ibstock cheaper than the local approved dealer.
Generally - These tyres are not quite in the same sport league as the Goodyear F1s I also use but they are perfect for the barge and the way I drive it (generally I don't hang around). They give a surprising amount of grip and sharpen up the handling to just the right degree for such a ponderous wagon. I would thoroughly recommend them for any saloon with sporting pretentions or for the more demanding driver.
Clive
500E - shod with Goodyear F1s
E320CDIT210 - V... Ultracs
Clive
