Work done by experienced Merc mechanic.Taking head off again to day.Oil level and Gauge OK.Thanks for interest-will pass on result.
PeterD. Melbourne Australia
W123 Oil pressure problem solved---cause ,a lump of Silistic sealer came loose from a previous attempt to seal the valve cover (previous owner) my mechanic found it when he stripped the pressure regulator the second time-just luck.the lesson only use oil soluable sealants .Thanks to all
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
