w123 280ce window motors
Status
Not open for further replies.
dom
bournemouth
driftboardbags.co.uk
one of the rear windows has started to loose its oooomph, and struggles to reach if at all it's original position.
does this sound like a replacment motor or a mechanical fault to you guy's in the know?
if you think it is the motor would it be the same type of motor as in the passanger door, ( i have one of these that i could use.)
finally how painfull will it be to fix (very i suspect) thankyou!
jaques2k
Jakobstad, Finland
I had about the same prob. with my power window on the drivers front door (MB 380SE -85), the motor did get power, but the window wasn´t moving. I had to remove the door panel, and unscrew some screws, and take out the motor to test it. It was the "gearbox" attatched to the motor, which had got stuck. I started turning the motor around by hand with a plier, and after that it started to work. I cleaned it up and filled it up with new grease, and it has runned smoothly since that. I also lubricated the guide rails for the window in the door (all the moving parts).
I´ll guess it´s the same thing for you, if the windows are going slow. I don´t know what type of motor, or how it´s fitted on a CE, but my guess it´s a mechanic thing. Try lubricating first, if it doesn´t help, it´s likely the electric motor.
Good luck!
Status
