W123 - adjusting height of sunroof panel
Peter C1974
Buckinghamshire
1985 W123 230E & 1991 W124 200E & 1999 W210 E240
Gents,
My W123 saloon is fitted with a factory fitted manually operated sliding sunroof.
The sunroof panel has dropped slightly on one side, by approx 2-3mm. When shut, the rear left edge of the sunroof panel is lower than the roof panel, which allows excess water to collect and drain down the nearside of the car.
I tried pushing on the underside of the panel whilst operating the closing / locking mechanism but that doesn't seem to help.
Any ideas how I can adjust the height of the sunroof panel in closed position?
Regards,
Peter C
brandwooddixon
Wolverhampton
S63 Coupe 2014
Have a look at the W210 DIY thread regarding sunroofs in case that gives you any pointers.
I have no info on the 123, are not the side rails adjustable
Peter C1974
Peter C1974
Buckinghamshire
These are photos of the sunroof rails:
Do the rails look adjustable? I think that the screw fixings are just there to secure the rails to the roof and they don't feature any adjustment options.
Any ideas?
I have a few things that I can print off tonight for the 123,,, they are the same as the 124 I think and I should find something there for you
Peter C1974
Peter C1974
Buckinghamshire
That would be very much appreciated.
Peter C
OK I have them ready to send :D
Peter C1974
Peter C1974
Buckinghamshire
I tried sending you a private message but your inbox is full.
Thank you.
Peter C
It is always full :(:( 2 papers sent that should cover it all :D:D
Peter C1974
Peter C1974
Buckinghamshire
Received, thank you.
Please remove you address in edit :D
www.ckinsurance.co.uk
