W123 Dashboard Problem
Status
Not open for further replies.
Nick Gilbert
oxfordshire
Hi there...
I have an '82 W123 280TE and the electrical gauges on my dash only work intermittantly.
The Economy & Oil Pressure work fine as does the Speedo as they are mechanical but the Fuel Gauge, Eng Temp and Rev counter, being electrical, keep coming on and going off.
I checked and replace any dodgy fuses in the eng-bay bulk head but no change.
Anyone got any idea's as to why and how i can fix it?
Many thanks
Nick
TimN
Hertfordshire
I would pull the large plug off the back and push it back on a couple of times. There are some proprietry electrical cleaning spray that you could try. If this doesn't work then you will have to open up the instrument cluster and take a look at the condition of the circuit board. Sometimes dampness can get inside and destroy the tracks. If so you can loop bridge over the damage with a bit of wire.
N
Nick Gilbert
oxfordshire
TThanks Tim
Did what you sai and now its fine.
I also changed all of the ceramic fuses. Some were badly corroded, some were ok.
Thanks again for the advice.
Cheers
Nick
Status
