bikerogg
- Nov 13, 2012
- Location
- WARRINGTON CHESHIRE
- MERCEDES 200E
Hi All,
I hope you can help with this problem. The hazard lights on my 200e only work with the ignition key turned this only has to be turned to position 1 and then they work as normal. I have the same problem with my courtesy lights, if the key is turned to position 1 they work as normal ie when you open the door they come on and when you close the door they shut off. As soon as you remove the key they will not function at all in any position. Any help would be appreciated. Cheers Paul.
