W124 230 TE poor idle (again)
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
OK reume:
Bought car very cheaply with intemittent idling problem.
Replaced idle control valve, no better.
Had it at a Bosch service centre on Friday who said that there was no signal coming from the ECU to the idle control valve.
Sourced another good ECU from a car with no idle problem.
No better.
Any pointers at what I should look at before spending more money?
If I take it to a main dealer would they be able to "plug it in" and give me a definitive answer?
Cheers
Tony
dragon
Banned
Buy a newer better car if you don't enjoy the fun.
The Crooner
The Crooner
2006 R320 cdi
My wife's "newer, better" "if only everything was as reliable as a XX", has cost more in one repair than I have spent on the 230, and I still have change.
I do enjoy the fun, I'm just getting a bit frustrated because I cant mend it with spanners and common sense.
Tony
The Crooner
The Crooner
2006 R320 cdi
Agreed, trying to trace the wiring.
I think a part of the engine to ECU loom may be defective.
Tony
The Crooner
The Crooner
2006 R320 cdi
To all who suffer from poor idle.
Make sure your idle control valve is fitted the right way round.
DONT ask me how I know...
Good one and I am pleased its sorted :D
The Crooner
The Crooner
2006 R320 cdi
Yeah, that and a very poor connection to the three pin temperature sensor, which we resoldered.
Going to have to replace some parts of the accelerator linkage as there's a lot of wera there.
Also noticed today a pump in the heater circuit, it comes on with the ignition.
What is its purpose?
Tony
Tony
To circulate the water when at idle, so that the heater keeps your tootsies warm
The Crooner
The Crooner
2006 R320 cdi
I thought I would post up a "where we are" update.
My neighbour and I have had several tuning sessions with the car. I had already changed the idle control valve - when it was refitted correctly it made some difference to the idle.
Since then, and with the generous help of many other posters we have probed all of the controllers and sensors.
We have also rebuilt the accelerator linkage and adjusted the control rod to fuel accumulator length, to ensure that that it was set correctly at rest. This made the biggest single difference to the running and idling of the car, and I urge all those with poor running/idling/intermittent faults to examine carefully the operation of their linkage.
Today we have tested the air temperature sensor and the engine temperature sensor, which both gave abour 4.5Kohms at cold. Television told me it should be 6 at cold, but I guess cold in Bavaria in winter is a little different to the cold I experienced outside today on the East Coast.
So now we have a good idle, the car has stalled once in the past 10 days, and its performance is quite sprightly compared to when I first got it.
It has had a new rotor arm, plugs and plugleads, and a very well cleaned dizzy cap.
We are now left with some quite discernable "hunting" at idle, the rev counter moves by at least 100 rpm in either direction.
We have probed the voltage on the lambda sensor, and there are voltages there, and they fluctuate with engine revs.
So I think there are two final things to do:
change the lambda - it looks very original
take off the inlet manifold and replace the gaskets.
Comments from the gurus please.
Tony
Well the cure for hunting on the V12 engines is the inlet manifold gaskets, so why not on this,,even if it is a vacuum fault it will show different voltages as the revs go up and down, so care is needed in how you interpret any meter reading,,conformation can be had by revving the engine on the throttle..
You said the voltages were changing as the revs go up and down on idle, to double check this, alter the throttle by hand to see if you get the same voltage change, if the voltages do change then that item where the voltage changes could well not have a fault
The Crooner
The Crooner
2006 R320 cdi
I'm sorry, I confused you. The voltages on the Lambda sensor vary with throttle position, as well as at idle.
Then I think that the 02 sensor is working correctly, its purpose is to measure the richness of the fuel, as the enine hunts then the exhaust gas changes and the 02 sensor is trying to correct it, I wonder what would happen if you disconnected the 02 sensor from the engine ECU to prove the point
kth286
E320 Coupe 95
A simple vacuum gauge will show a manifold leak.
www.W140.co.uk&www.r129.co
