Uncle tony
- Aug 11, 2019
- Location
- Ravenshoe 4888
- W124 230e 1989
Im wondering also could that lever be associated with my cruise control,,my crusie seems to work however..
,,, hello,,omg this is my issue 230e,,that little spring from that little lever, i has a tab to take a spring just as i thought,,thanks bloke,,,now pls tell me did u manage to get it mounted at the intake end,,is there somewhere obvious i can c or feel once i remove oil filter??,,,,cheersHi all, all the best for 2009 etc. Due off the germany in the 230TE again later in the month and finally got around to replacing the stiff accelerator cable. However, I already noticed whilst looking at the old cable in situ, to the throttle body end that a spring was missing from the bottom of the guide lever, and that in the rest position the guide lever wasnt quite touching the idle microswitch- yet the car ran fine......
so on installing the new cable I have also got hold of a spring for the guide lever, but, for adjusting the new cable haynes seems to make reference to a 'connecting lever' that 'is a flat adjustable lever that joins the guide lever to the throttle lever' but I cant see this lever on the assembly- haynes notes it is connected to the guide lever by a ball socket joint-? the only connection between the guide lever and the throttle lever on my car is the roller and L shaped cut out on the guide lever:-
So is haynes making reference to a set up not found on the 230 (fuel injected) or is my car missing components, or some misunderstanding on my part? Apologies for the long and difficult to understand post- I'm a bit stuck
Hello dreamer,,,theres a member sacco he posted a similar issue,,he mention he had to remove the oil filter to get his hand down under inside i gues near oil filter is a hidden mount for a spring,,.my car is auto...but u know what i think the 190e setup is same as mine...i think that little lever operates the throttle body butterfly..whereabouts are you in this world dreamer?, all these internet stuff is pretty good aint it,,Tony Please dont call me mr just dreamer will do . Dont you mean that you will need to remove the air box ,not the oil filter . Is you gearbox a manual ,?only reason that i can see your throttle linkage is different to my picture .
Yeah,,,what is part no 2?Tony i found this one also . View attachment 52053
Omg,,,thats gotta be it,,makes sense the style of it,,ok,,brilliant unreal,,,i read your other post for google i will try it,,i still in explore an learn with computer stuff, that spring Dreamer,,man i wasn't certain there was one but my eyes an nouse was tellin me there should be somthin there im so happy i aint goin mad, u should c the return i imrovised up it would give u a laff, ,,anyways its flithy cold up here on this mountain tonite the cricket from uk is on the telly so im so relieved about the spring thing i reckon i just go to bed keep warm watch cricket an wake up an fix my merc...thankyou,,,I find number 2 in the diagram is a spring and the number is View attachment 52059 A102 993 23 10 .
Righto,,cheersTony you know when you go to google search ? if you look to the right top of the screen you will see images click on it. Then the search box will change .You can now put any thing in the search box you need to know about --- try it out .
