xitrum_dalat
- Dec 16, 2008
HI every body. I'M NEWBIE HERE,HAVE SOME QUESTIONS .
AFTER CHECK ERROR CODE BY HOME MADE CODE READER,
I FOUND CODE 23 IGNITION OUTPUT STAGE 2 OR COIL(3-4)
AT FIRST I THOUGHT THAT IT'S IN MEMORY ERROR B CAUSE
I'VE CHANGED ALL NEW 3 COILS.( the coil for 3-4 is broken)
SO I ERASED THAT CODE. AFTER 1 DAY ........ RECHECK
IT APPEARS AGAIN !......
THE SITUATION IS
THE ENGINE IS RUN PROPERLY, EASY TO START
RPM WHEN HOT IS 850 RPM .... NO SWING
RUNNING SMOOTH
BUT THAT CODE 23 ANNOY ME VERY MUCH
IT INDICATED THAT MY ENGINE HAS PROBLEM.
WHAT I'VE DONE IS AS FOLLOWS
CHANGE 6 SPARK PLUGS
CHANGE NEW SPARK WIRES
CHANGE 3 PLUGS UNDER COILS
CHANGE O2 SENSOR ( B cause it short circuit in heater)
CLEAN ALL PLUG RELATED TO COIL AND IGNITION BY DEGREASE
CONTACT CLEANER
OPEN THE ECU THE CIRCUIT LOOK GOOD THE 2 BIG CAPACITORS
ALSO LOOK GOOD GOOD SHAPE AND NO LIQUID LEAK.
SO I CLEAN THE PLUG TO ECU BY CONTACT CLEANER TOO.
MY ENGINE WIRE HARNESS HAS BEEN CHANGE 5 YRS AGO
BUT THE ERROR CODE 23 STILL THERE !
PLEASE GIVE ME SOME ADVICE.
THANKS
THE SITUATION IS
RUNNING SMOOTH
CONTACT CLEANER
THANKS
