W124 320CE rear window not working
col320ce
Australia
320CE Sportline
1993 W124 320CE
Rear right electric window not going up/down. All others work ok, fuses ok. I can hear a relay click when I press the window button but can't hear anything else (no motor noise).
I suspect the problem is between the relay and the window motor.
Any further ideas on this - where should I look first?
I can't remove the trim from infront of the rear window to get to the mechanism.
Has anyone got 68-456 notes on how to do this?
Thanks for any help
This could just be the motor stuck,,with a sticky carbon brush,
I can let you have the door trim removal instructions
col320ce
col320ce
Australia
320CE Sportline
Thanks, PM sent with my email address...
Often just giving the motor a clout, will bring it back to life when a brush is stuck
col320ce
col320ce
Australia
320CE Sportline
Motor replacement
I have the panel off and can see the motor (driving a cable). When switching the window switch there is 12V going to the motor. I have moved the motor around a bit and can't get any life out of it.
Can the motor be replaced without messing around with the pully arrangement? I tried to separate the motor but is pretty tight so did not persist as I did not want to break anything ...
Thanks for any help ...
I can give you the info,,have you tried whacking it
col320ce
col320ce
Australia
320CE Sportline
I've tried whacking it. If you could send the info that would be great. I assume you still have my email?
Will post a picture to - tomorrow.
What did I send you before so that I can find the address
col320ce
col320ce
Australia
320CE Sportline
The door trim removal instructions - see the top of this thread. I can PM you again if required.
Details sent :D
col320ce
col320ce
Australia
320CE Sportline
Here is the motor
Looks like there is a problem getting 12v through to the bushes.
I suspect the box that is attached to the green cable is broken. I will need to remove it to work out what it is?? then replace it...
I think it should work after this.
The brushes do not look good,,plenty of life, looks as though it be arcing
Dec
Ireland.
W202
Don’t replace anything until you have cleaned reassembled and tested.
Dec
col320ce
col320ce
Australia
320CE Sportline
Will clean and check. The black box looks like it is a thermal overload protection unit. If not working I will short it out and see if this gets it going.
Yes they do have one
Dec
Ireland.
W202
Col. What state was the commutator in, thats the part that needs a matchstick and sandpaper to clean. If that box is a thermal overload protector it would reset itself after a short time.
When you clean and reassemble, run the motor on a bench, independently of the cars electrics by means of a battery charger.
Dec
Dec
They should re set Dec but they can go faulty
Dec
Ireland.
W202
Agree Malcolm just don’t like to see it being taken apart until he has tried cleaning and testing first.
Dec
