Hi, the ABS warning light came on yesterday on my 1995 e220. The brakes still work fine (without ABS). The light is on all the time. The only other symptom is a slightly erratic idle, when you brake to a standstill in Drive the revs dip and it sometimes stalls. I replaced the OVP relay with a new unit about a month ago to cure a starting problem. the car now starts first time without any problems.
any thoughts? I see from previous posts that the wheel sensors often accumulate rust and other crud. would this cause the ABS to fail and if so how do you go about cleaning them.
thanks for your help
Neil
Neil
