W124 AT gear selection not smooth
TharunKumarV
W124 300D /1993/OM603
Hello All
I am Tharun from India, it was dream to own a W124 from my child hood and my dream came true last year. Found a W124 300D AT masterpiece car in a average condition.
Due to pandemic had to just move the car from the previous owner parking lot to my friends garage.
identified few works on the car, which is listed below.
1. Body work and paint job
2. Sunroof drain leak
3. Front strut was weak
4. Lower arm rubber kit was ruined
5. GEAR SHIFTING WAS NOT SMOOTH (initially thought transmission oil and filter was the issue)
6. Basic electrical issue.
First to start of with body work and paint
With minor challenges Car turned to a good shape. Thank to my dad's very old friends, who gave a brilliant job
All other work was completed in 3 month due time and ran like a piece of art. but the gear shifting is bit harder. Kindly need your support in solving the issue.
regards
Tharun Kumar V
ajlsl600
france
Wondering. R u talking of rough changes at all times or when starting off. Is yr idle speed correct.? U say u changed oil and filter, did oil meet the MB spec?
ajlsl600
france
What did the old filter look like? Was it clean?
TharunKumarV
TharunKumarV
yes it is about the rough changes at ever gear shift. MB suggested oil and filter has been replaced accordingly.
TharunKumarV
TharunKumarV
it was clean, ideally my mechanic mentioned, why do we change if the filter is clean. but still wanted the filter to be new
rayhennig
1991 300CE-24 Sportline
Do the gears change at the correct points/speeds?
Are the vacuum connections to the gearbox intact? No vacuum leaks?
Is the bowden cable from the accelerator linkage to the gearbox attached? This changes change points and ferocity of change.
RayH
TharunKumarV
TharunKumarV
RayH
Gears change based on speed feels good.
need to check Vacuum connections - Could you please specify what i need to look at.
Cable is connected to acc linkage - But do i need to check or calibrate it ?
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
Hello and welcome Thanum.
Doug1234
Bedfordshire uk
1997 w210 e300td
This link explains the bowden cable and what it does…. there is a video link in it that shows the cable and some other parts that can be adjusted.
Your problem is going to be either the cable is too loose or to tight …or you have vacuum connections that are cracked and leaking and want replacing. Other than checking the connections first then adjusting cable the other parts shown should not need touching.
Your w124 may have the bowden cable up in a different place , I think my old w124 had it above inlet manifold ? ,not sure it was years ago and the video concerns an American spec diesel but adjustment is all the same.
So check all those little vacuum hose rubber connections first and then move on to checking cable if no improvement.
mioba
Nottingham and Köln
The W124 has a million and one things controlled by vaccum.
As a start I would reset the adaptive gear shifts, some say it doesnt work, but it certainly did on my W124
further info on the vac issues here
and
rayhennig
With respect, highly unlikely. Adaptive/reset etc. aplpies to later, electronic gearboxes never fitted to 124s, to my knowledge.
RayH
^^^^agreed^^^^
Only the 722.6 and onwards were adaptive.
Earlier boxes as fitted to W124 were purely hydraulic except for 5th which was electronically controlled on the 722.5
