W124 break pipe replacement and bleedind up
Fergal1975
1988 w124 230 E
I replaced some corroded break pipes on my w124 . But now I'm trying to bleed the air out of the system. But cannot get a good pedal. Any tips ? I've tried to bleed from the top with help and tried pumping from the bleed screw back still no avail .
DREAMER NO2
W124 2.6E M103 1989
Is the brake fluid tank full to the mark .. its split in two and lots of people forget this. the rear segment some times is not full .Fill the flid tank and gravity bleed them ..open up to bleed and let gravity do it for you .
F
Fergal1975
1988 w124 230 E
Thanks I try see how I get on
DREAMER NO2
W124 2.6E M103 1989
Do you have a mighty vac vacuum tool . You can draw the fluid through with that . Or pick up an Esybleed system that fits on to spare wheel to pressurise the system from the fill tank then just break open the nipple one at a time keeping catrch tank full all the time .
F
Fergal1975
1988 w124 230 E
Dont have either but I have a couple of caps could probably make up something to put a slight bit of pressure in.
DREAMER NO2
W124 2.6E M103 1989
You need a tyre valve the nut retaining type . You dont nee much presure on the system to bleed it .
Put this number in Ebay search 360354247173 for more info on bleeding them its on the information so scrolle down the page to view it
joderest
ML270 2003
The vacuum type do work well, but are a bu**er to seal to the bleed nipple to stop drawing in air.
joderest
ML270 2003
I Know, but i like to see the fluid run clear with no air bubbles.
I just keep pulling it through until i know its come all the way from the master.
F
Fergal1975
1988 w124 230 E
Tubless tyre valve and a bicycle pump and away we go bleed up thank you all .
DREAMER NO2
W124 2.6E M103 1989
Bike pumps no good it must have pressure on the system all the time , not just one pump of cycle pump . Read the ebay listing for how to go about it even if you use your spare car tyre it must be deflated to the right pressure to bleed it to much it will spoil the seals .
...... even if you use your spare car tyre it must be deflated to the right pressure to bleed it to much it will spoil the seals .
if you don't deflate the spare tyre pressure you'll end up with fluid just about everywhere ..... apparently! :rolleyes:
Droverunner
West Cambridgeshire
Ha ha yes and that's why I decided to go for a self contained pressure bleeder when my Gunson got old. The ideal pressure range for the spare tyre was quite narrow and I was forever topping it up just enough to keep in that range.
www.ckinsurance.co.uk
