Mercedes 190E
- Sep 11, 2008
- Location
- Walsall
- Website
- stores.ebay.co.uk
- 2013 C220 CDI, 2004 A140 Classic SE (Parents!)
I always use NGKs in my cars. Never had a problem with them.
Thanks very much guys.
Kth, sorry for a daft question, but which direction is 'normal' please?
As an alternative, I've also been thinking of turning the crank by removing the spark plugs as Malcolm suggested, because the plugs are due a change, so could kill two birds with one stone, and avoid removing the fan cowl. Haynes recommend a particular type of Champion plug, so is that the type I should go with or are there better ones now?
Thanks David. I was cautiously following Haynes to the letter until my friend encouraged what proved to be an act of folly.
I will definitely not use the car until I've drained it. I wasn't sure what the effect of overfilling was, but google soon put me right!
I did have to manoeuvre it on my driveway a little today, to position it in preparation for removing the starter motor, and I couldn't drain it before that, but it was short and gentle, so hopefully, no damage was done.
i removed some fluid from my transmission via the use of one of these.
http://cgi.ebay.co.uk/180cm-Siphon-...vels?hash=item3ca43c7cf2&_trksid=p3286.c0.m14
the one i got (not the actual one linked above) was pretty poor at getting the fluid to the exit of the tube by pumping it with my hand due to the length and vertical positioning of the ATF tube, so i opted to suck it in with my mouth like a straw. this was OK as the "pump" area, which was clear on mine, filled up just before it would end up in my mouth (!!!!) and then i quickly withdrew the pipe from the dipstick tube into a bottle that i placed next to it and hey presto, a few ml of ATF has been removed.
quite messy though, but no ATF was drunk in the making of this post
