W124 Coolant leak
RiceBurner
1991 230TE
Pretty sure I've got a coolant leak on my 1995 230TE.
Have filled the resevoir up once a week and the car doesn't do that much milage.
Water temps have been remaining static at around 80 during all driving.
Does anyone know of, or have access to a "coolant flow diagram" so that I can trace where the coolant goes in the engine, and associated external bits (rad/pump etc) and attempt to find the leak?
I've a funny feeling it's dripping onto the fanbelt - there's some "spray" on components that would be in the right place to be flung off the belt. Also - one or two of the coolant pipes were recently replaced (by the previous owner, personally, no proper records) - so this could be the cause.
Any help would be gratefully appreciated!
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Water pumps and radiators are the usual suspects on W124s. I'd suspect the pump
Nick Froome
Gazzaj
Mine was leaking through the front, and spraying on the aux belts from the pump as it had seen its day. Also I know that some, not all but some thermostat housings are plastic, and can crack, check that too at temperature, as mine leaked from there too.
It will be the water pump, put your finger under it (engine off) and I bet its wet
R
RiceBurner
1991 230TE
Hmm - didn't have a chance to do anything about this and now (after a 500 mile run) I've got a little more than a weep....
it's now a constant "drip drip drip" and it's draining the whole system.
I've done some looking (without removing anything) and it looks to me like it's coming from the pump - IF Haynes is right and the pump on the 4-cyl 2.3 is the unit on the same shaft as the radiator fan and driven by the main belt?
Given that the pump is metal bodied (as far as I can tell), I assume that what's actually gone is the gasket??
ie - When someone says "the pumps gone", is the gasket the main suspect?? Or will the pump itself have broken??
What sort of repair costs am I looking at?? Car is going into AroundTheBenz at Ford tomorrow for a compression check and quote.
Given that the belt/radiator/alternator/and bits all needs to come out - am I looking at 5-8hours (a guess) labour charges "just" for a gasket* ??
I currently don't have time to do the job myself (if I could?) and I need the car next week for a trip to Holland!
*assuming it IS the gasket - in my experience they do occasionally go and are usually a simple, if time-consuming fix - my experience is with motorcycle engines btw - not cars.
Number_Cruncher
1995 W124 E300D TE
It will be the pump itself, not the gasket - although, of course, you will need to fit a new gasket with the new pump.
R
RiceBurner
1991 230TE
ouch - I take it these aren't cheap. :(
How do they fail?? is it an internal seal (if it's internal, how does the water get outside the pump?) or something?
As number cruncher,, should be no more that 1½ hours for a new pump, you do not need any other test
R
RiceBurner
1991 230TE
Will the garage spot this on first inspection then, without doing the test? I won't be there in person to show the mechanic what I've observed.
Any ideas on what a pump would cost?
From GSF or euro about £87 I think, it is a very common fault and it happened to me when the car was 2 years old, if the water is coming out under the pump that is all that needs doing
R
RiceBurner
1991 230TE
I know that AroundTheBenz only use OE parts (and I'd be happy to have a genuine Mercedes part used tbh), so even if it's twice the price that's good news to me.
I was worrying about a £500+ bill.... (which would be more than the cost of the ferry tickets to Holland and back!!)
