W124 differential
3ps
I just bought a W124 220 7 seater. The diff was slightly noisy, which I expected. On the way home it dumped it's oil and I kept driving it. It sounded like a hammer drill in masonry :(
Anyway, I've located 2 units in Prestige Allparts and Dronsfields. I've never bought major items at a breaker before. Can they been trusted?
It's just that I asked what cars they came from and was told one had 75k on it and the other only 45k! It just seems to good to be true although at 20% the cost of a new one........
I would trust them,,they are not fast moving items
ncooper
York
1984 Mercedes Benz 280 SL,1993 Mercedes Benz 190E Manual,1993 Mercedes Benz 190E Auto
Not really,as Malcolm said,there isn't much demand.
I recently paid £85 inc delivery for a second hand Land Rover rear differential which is now fitted and working perfectly.
List price...£600!!
Regards,
Nick.
3ps
OK thanks.
Another Q.... the car has ABS. Does that affect the differential I pick or will it just slot into whatever ABS components I have?
OK thanks.
There may be just the one in the diff,,the hole will be there anyway
kth286
E320 Coupe 95
Yes it can make a difference as some 124 came with ASR which uses two sensors and maybe in different positions on the diff.
You actually need the part number of your own diff and the part number of the diff you are buying to really see what's what.
3ps
Aha, thanks for that!
Alex Crow
Super Suffolk
also input and output flange sizes may vary, and ratio may vary. part number is the ideal way of matching.
wireman
lancashire
All later 124 models have ABS. It was an option but became standard around '86.
3ps
So, if my VIN is: WDB1240822F286221
then I'm looking for
A 124 350 31 74 AXLE HOUSING
REAR AXLE HOUSING WITH DIFFERENTIAL, AUTOMATIC FOUR-SPEED TRANSMISSION
ABS 1:3.27
or
A 124 350 73 14 HOUSING
ASD 1:3.27
Alex Crow
Super Suffolk
do you have abs and asd, or just abs? there will be an asd warning light on the dash to the r/h/s if fitted.
3ps
I don't think I have ASD. I'm not familiar with the dash yet and amn't close to it.
But I suppose my question is.... would somebody in a breakers who has pulled a differential assembly have one of those part numbers to hand, or do I need to find a different part number?
It will have the part number on it..
Also ask robparker on the forum,,he is breaking loads
Alex Crow
Super Suffolk
those are THE part numbers. any breaker will definately have the right one/ they are sure its`s the right one/ probably the right one/ will definately fit/ might need simple modification but easy done/ fairly easily done etc etc. the part number is stamped onto the machined face at the rear of the housing at the bottom right corner, along with the ratio. cast numbers on the side of the housing will not do.
3ps
OK thanks.
I asked the breaker to tell me the part number he had and it matched the BAS only one. He also said he used my VIN to check I had ABS only, which I do, as I checked my dash.
So I guess I can trust him. Although he could just repeat back the part number I want after looking up my VIN I guess!!!
kth286
E320 Coupe 95
I have checked your car spec and you only have ABS.
3ps
  • #18
I'm getting close to ordering a differential. I've found a good deal on one with 98k miles on it. Can somebody please help me out by checking if the following car had ABS or ABS/ASD?
WDB1240222C058393
Number_Cruncher
1995 W124 E300D TE
3ps
  • #20
I don't have ASD. The part I'm asking for now is the one in the breakers. I just want to be sure that the car it came from was ABS only. Thanks.
