w124 e36 amg electric seats
mossco
stowmarket, suffolk
1997 c36 W202 AMG
so i've made it back with my 1997 w124 e36 amg, love the car but now its down to sorting out the few problems the car has.
the electric drivers seat works perfectly in every direction, however the passenger one doesn't really work at all!
any ideas? do they have any common faults?
thanks
adam
I am pleased that you like the car Adam,,they are nice,,your fault could be with the comfort pack under the rear seat or on the switches for the seat. I understand that the switches can give problems, a few checks with a voltmeter should tell you
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Glad your pleased with your new purchase, post a few pics of your new pride and joy.
Regarding your electric seat, my only experience is from my C43, I would intially look at your fuses, on a 202 you have 3 fuses per seat IIRC, not sure if the 124 has a rear fuse box but check there as well as on a 202 4 of the fuses are there.
Also may sound stupid but try your seats with the doors open with the keys out of the ignition as the comfort module "should" then come into circuit and put power onto the seats (FYI also the windows i believe)
Alex Crow
Super Suffolk
hello adam, locate the fuses under the bonnet and give the seat ones a good twist from side to side (probably 25A blue ones on rhs of fuses). the other advice given above should also be followed but you will only find one fuse box, hope that helps.
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
cheers for the info, i did have a quick look at the fuse box under the bonnet, but i could actually see any for the seats?
I was wrong in my first post, the comfort pack only deals with the windows. I have added it the list to check when I turn on the other computer, though the info is limited on these there is some info.
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
had a quick look at the fuses under the bonnet and can't see anything relating to the seats?
however the headrest still goes up and down which is handy!?:rolleyes:
Is the switch in the doors or on the console I forget now
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
switch is on the doors in the shape of a seat
As mine then :D:D I will dig some info up soon though you may have to lift the seat from its fixings
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
ooh that sounds like fun!
many thanks anything you can find would be great!
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
Hi Malcolm,
just wondered if you had any joy on finding any info on the seat electrics?, i can't work out if you can PM people on this forum or not!?
Hi Malcolm,
You can PM after one month :D:D
I will take a peep now and see
Do you have memory seats please
I have sent you via Email the complete service info on the seats
Alex Crow
Super Suffolk
the fuses might just be seperate to the main fuse box. if so they will be under small black plastic covers, just forward or to the side of the main fuse box - do have a look for these.
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #18
thanks for that malcolm will take a look at that when i go back to work tomorrow. and cheers andy will take another look tomorrow.
mossco
mossco
stowmarket, suffolk
1997 c36 W202 AMG
  • #19
finally found the fuses they are next to the battery, had a fiddle with them and checked them but they both seem fine, no easy fix though so i'm assuming its either a motor or a switch?
