John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
I would be grateful for any help: The car is a 1989 W124 250 TD. The probelm: The left (passenger) front window and right rear window are failing to operate. The front left motor was very strong, although I accept that the rear right window motor has been weak and occasionally intermittent for a year or so. I have checked the 25A fuse at position G , which protects the circuit for this diagonally opposite set of windows (the others being Fuse H), and sprayed with electrical contact cleaner. I suspect no power is getting to the windows since I hear no clicking of the motors when the switches are depressed. Since 2 switches involved, seems unlikley to be a double switch failure. Is a relay in the circuit? I welcome any solutions.
John
John
