John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
My W124 250 TD (1989) has just failed its MOT (3.6.F.3) because 'the rear brake load sensing valve linkage is broken'.
I was unaware that there was such a link to the rear brake. Is it possible that the testing station are confusing the link rod (part 41) on the self -levelling suspension?
http://www.detali.ru/cat/oem_mb2.as...852F101441&CT=F&cat=506&SID=32&SGR=345&SGN=06
The only part I can see in the diagram that connects to the brake is part 140, the line described as the height contril valve to right spring loaded brake unit
However, since the part broken was described as a short rod which had snapped, I suspect they are confusing it with the link rod. If so, is this really an MOT failure (since it has nothing to do with brakes and I am not carrying heavy loads)? The ride is not bouncy nor flat - but very normal without loads.
The car was recently serviced, and I was told that I was going to need 2 new hoses (part 71) from accumulator to spring legs, and a new rear axle load valve sensor (which they describe as snapped). Does anyone know which part the latter is? (Apparently it costs £18.60 + £1.05) - is it part 59 in the diagram? I was not rushing to do this, but the MOT result is changing things! The suspension level fluid is low in the reservoir, and I suspect the drivers side pipe part 71 has leaked where it is corroded.
I am aware that MOT testing stations may be unfamiliar with the self levelling layout, and may be giving me a confused picture. The car was off the ramps and others on when I came to collect, and hence I have not been able to see the damage for myself.
Any advice would be gratefully received.
John
John
