W124 Estate Trunk / rear interior lights staying on - help please!
CJ124
Belfast, Northern Ireland
I've no idea why but the rear lights which are meant to come on when the boot or rear doors are opened have decided to remain on no matter what I do with the switch or the doors.
Now FYI, my boot lock motor no longer works, if that helps.
At the moment, I have to open the bonnet, lock the car, remove the C fuse which kills the rear lights and the locking. no perfect!
All advice will be very gratefully received. I'd much rather fix it myself then pay someone else...
Many thanks
Colin.
C
CJ124
  • #2
BTW - There was a bit of moisture but not any more.
I've stripped it down and sprayed switch cleaner on everything. No change.
Disconnected every multiplug I could find in the tailgate and still no change!
BlackC55
South coast
C43
Is the switch on the boot lid working?
Is the switch on the boot lock workiing?
C
CJ124
The dashboard switch does nothing to help.
I disconnected all relays and connectors and switches in the tailgate including the 2 microswitches in the lock mechanism and nothing changed - the lights all remained firmly on!
Let me have your Email address and I will send the details
star
Reading
Smart + others :)
i expect you have broken wires in the left hinge area, in the rubber tube.
What we can do as you cant PM yet, you put your Email address up at an agreed time, I will note it and you can then edit your post and remove it
please allow up to two hours its a large file any problems I can send a smaller one compressed
spud murphy
1997 202 C180 T
Hello all, wonder if anyone had a resolution to this problem?
I have the exact opposite whereby the boot lights will not turn on when the tailgate is lifted but will operate when the rear doors or interior lights are selected manually.
Any help greatly appreciated, thanks John
If you want the Work sheet for the rear lock and switches I need your Email address
spud murphy
1997 202 C180 T
Many thanks television hopefully email on its way to you.
Best regards John
spud murphy
1997 202 C180 T
Many thanks Malcolm, fluke meter being dusted off ready for action.
Much appreciated, John:D
